Hydraulic System 1600
Bob (wi.)
08-26-2004 09:57:05
Removed hyd. unit to fix trans. and when I replaced it the 3point and external hose dont work but steering does. It all worked before also dont have oil to filter. With extra shims only have 800 psi
J. Schwiebert
08-26-2004 13:59:09
 Re: Hydraulic System 1600 in reply to Bob (wi.), 08-26-2004 09:57:05
Need more details. Do you have steering at lower engine RPM's? Did you back out the by pass screw on the right side of the hydraulic unit? By the external hose, are you set up for only a one way cylinder? Is 800 psi the pressure on the flow divider or the manin system?
Bob (wi.)
08-28-2004 17:31:22
 Re: Hydraulic System 1600 in reply to J. Schwiebert, 08-26-2004 13:59:09
power steeringworks at 1000 rpm. adjustment valves on the side are set the way it says in the Oliver shop manual for 1600. The 800 psi. reading is ate pressure relief test hole on the left side of unit. I an using a two way cyl.
J. Schwiebert
08-31-2004 10:27:13
 Re: Hydraulic System 1600 in reply to Bob (wi.), 08-28-2004 17:31:22
Sorry I missed this post. What pressure do you have at the flow divider? Did you take the relief valve out and check it for dirt. What adjustments are you talking about? Do you have an Oliver or an I & T manual
