550 power steering pump specs
Stan(MO)
08-24-2004 15:19:32
Can anybody give me the specs of the Cessna power steering pump on my 550. This is the belt driven pump that activates the two cylinders (one on each side) which operates against the tie rods, NOT the integral pump that is built into the generator.
I'm looking for the Cessna part number, cu. in. disp., PSI, & GPM @ RPM. Any additional information would be appreciated, since I don't know much about hydraulic pumps.
I've priced some replacements from a couple of well known Oliver "dealers" but the price is $500. Hope I can find a reasonable replacement at a lower price.
Thanks in advance.
J. Schwiebert
08-25-2004 09:37:45
 Re: 550 power steering pump specs in reply to Stan(MO), 08-24-2004 15:19:32
Most Cessna built pumps have the pump model number stamped in one of the mounting flanges. Check there first. If it is not a priority part you may be able to go through Cessna. If you think your price is expensive, in one of the classes I taught the hydraulic pump was over 13 thousand.
