Super 55 transmission oil level
BigPapa
08-23-2004 17:37:48
I posted about a shifter problem the other day and mentioned my axle seals are leaking. One person mentioned that I should check my transmission oil level using the pipe plug above and to the right of where the PTO shaft comes out of the rear of the tractor. Is this the proper plug to check the level? The plug in question is below the axle seal level. If this is the proper check plug then I may have the tranny and rear end over full. The oil leaks out on level ground. Thanks.
jakej
08-24-2004 09:06:25
 Re: Super 55 transmission oil level in reply to BigPapa, 08-23-2004 17:37:48
Thats the proper way to check the oil level.
jeinsc2
08-23-2004 19:09:43
There is a pocket of oil for the outside axle bearing . about 1/2 cup always on seal & bearing.
jeinsc
