55 Shifter outta whack.
ollie nut
08-21-2004 20:08:33
Left me with only neutral and reverse. I know the quick fix, but the Oliver expert down here says the real problem is the bearings are loose on the clutch shaft.He says I should split the tractor and tighten the bearing pre-load. Is this true?
Thanks!
Kelvin
