Super 55 hydraulics update,
Super-55
08-21-2004 20:06:19
I managed to get all of my parts, and gaskets from my AGCO dealer in Everson, Washington. IN STOCK, no less. However, the ring and vanes for the pump are now obsolete, but he happened to have one in stock. In fact, he gave me a deal because it was around for so long.
If you want a new Vickers pump, it goes for $1,800. Who, needs hydraulics anyhow= P
86turbodsl
08-23-2004 03:40:54
 Re: Super 55 hydraulics update, in reply to Super-55, 08-21-2004 20:06:19
The vanes and such may be obsolete at the AGCO dealer, but they are Vickers parts that aren"t obsolete, and they are readily available from any Vickers distributor for less than $300. I bought my Vickers kit by part number and had it in a day.
Go see my rebuild article:
www.geocities.com/dieseltempo
D Hastings
08-23-2004 19:13:04
 Re: Super 55 hydraulics update, in reply to 86turbodsl, 08-23-2004 03:40:54
I read your artical at www.geocities.com/dieseltempo It is good to know thanks. One observation though. I wouldn't recomend using a petroleum based greese on o-rings as it will cause them to expand and fail. I would use plumbers greese or somthing that is compatible with bunna rubber. They sure are a nice tractor!
J. Schwiebert
08-23-2004 15:09:56
I work with a Vickers sales guy and we checked his screen for a 550 pump vane kit and according to his Vickers screen it is gone. I did not check the smaller pump. Do you have a kit number?
Super-55
08-23-2004 23:55:25
 Re: Super 55 hydraulics update, in reply to J. Schwiebert, 08-23-2004 15:09:56
This is out of the website on the rebuild,
The relevant part numbers are Cartridge kit 912058 ($225-290, depends on supplier, call around), and Seal kit 229236 ($8-9).
I have found a possible source, but it is being checked out. If successful I will post.
Super-55
08-23-2004 13:05:43
Well, this is turning into a real treasure hunt. I don't usually bother with my AGCO dealer here in BC, because they aren't much of an Oliver parts dealer. But I decided to phone them anyhow. They say that they have the rebuild for $785CDN. I finally found a Vickers dealer in Vancouver. The part numbers off of my Vickers castings don't make sense to him, but he is going to do some checking. The vickers number I have on my ring is 143121, the cover has 1 0-35-21B and the body casting number is 143440. Do you know if these numbers jive with your numbers? Any help would be appreciated.
