Could be just the rails
Super-55
08-20-2004 07:48:47
There are a couple of things it could be. The shifting lever could have jumped the rails. That's the easiest to check. Look for the two springs and make sure they are okay, and line up the rails.
Another possiblility, If the forks have jumped the coupler you will have to remove the top. It's really heavy so you will need to rig up a hoist.
If you do the axle seals, get the full manual from the Floyd County Historical society. It is expensive, but well worth it. Inspect your bearings. They are available from your local supplier, you don't need to go to AGCO and pay big $$$$.
Good luck. If you need help post back.
Jim P
08-20-2004 09:19:30
 Re: Could be just the rails in reply to Super-55, 08-20-2004 07:48:47
Yep, pull the shifter and line up the rails. Common problem.
BigPapa
08-20-2004 09:55:04
 Re: Could be just the rails in reply to Jim P, 08-20-2004 09:19:30
So I don"t need to pull the hydraulics off, just pull the shifter? That would be nice. Thanks fellas!
BigPapa
08-20-2004 20:15:36
 Re: Could be just the rails in reply to BigPapa, 08-20-2004 09:55:04
Pulled the shifter and lined up the rails and she works! Thanks!
Jim P
08-21-2004 06:30:37
 Re: Could be just the rails in reply to BigPapa, 08-20-2004 20:15:36
Nice job, when that happened to me I thought my whole tranny was gone. With the help of the people here I found it was the easy rail fix. The 550s are like little Sherman tanks, not much is going to stop 'em! Knock on wood....
