Swapping a hydraulic to a mechanical lift Oliver 8
Jeff Oliver
08-19-2004 20:00:23
What is involved in doing a swap? I am wanting to move the hydraulics from a Super 88 to a Fleetline 88 that has the mechanical lift. The Super is going to be used as a puller and the guy doesn' want the unit and I am wanting to put it on my 88 to use in the field. D I have to swap the entire unit as in shifter and all or just the hydraulic part? Any extra parts I will need or will have left over?
Thanks!
J. Schwiebert
08-19-2004 20:13:31
 Re: Swapping a hydraulic to a mechanical lift Oliv in reply to Jeff Oliver, 08-19-2004 20:00:23
You will also need to swap the imput shaft in the transmissions. The power lift drives from a seperate gear behind the rear bearing. You will have the PTO support bracket left which I would make sure the puller has especially if they check him for horsepower. It supports the center of the PTO.
