question for J. Schweibert
luther
08-18-2004 18:57:47
Hi J. Hope you had a good vacation. Got the steering line on our 1850 fixed what a bear to get off and on. Got a question on my White 110. When I'm baling with it I have too clutch at times as usual well it started to grind when I pushed in the clutch for a few minutes, now it seems to get worse as the r.p.m.'s are raised, you can't hear anything at all at low r.p.m. I thought maybe the throw out bearing was locking up at high r.p.m. but the guy working on it hasn't pulled it apart but he thinks a bearing is going out in the over/under. The clutch has no more adjustment left on it and there's no grease tube for the throw out bearing. I did notice while baling in first gear on a steep incline going down the hill it seemed to grind as it held back everything. It also seemed to be grinding on the last day of baling in first gear in heavy hay. Could it be something to do with the p.t.o.? Not hardly I don't think because it grinds without the p.t.o. on in any gear at higher r.p.m. It doesn't matter what position the three speed shift is in either. Any suggestions are greatly appreciated. I think they're going to tear into it tomorrow I hope I might know more by tomorrow evening. Thanks for all help!
J. Schwiebert
08-19-2004 10:45:05
 Re: question for J. Schweibert in reply to luther, 08-18-2004 18:57:47
Luther: Go to www.hartparroliver.org, Find one of my posts and send me a message. I have some questions for you also.
J. Schwiebert
08-19-2004 10:44:22
Luther: Go to www.hartparroliver.org, Find one of my posts and send me a message. I have some questions for yout also.
