Oliver 550 fix
Dennis H.
07-03-1999 17:29:47
I don't know if anyone else has run across this or not. The grease tube that runs from the outside of the case to the PTO bearing costs close to $70 from the dealer. Mine had a rupture from age but I wasn't about to spend that for a replacement. I took the head of the hose where it crimps on to the rubber and cut it off with a hacksaw as close to the top of the nut as possible. I then drilled it out and tapped it with a 1/8 NPT and bought a flex tube for a grease gun at Walmart ($5) and threaded it on. Works like a charm and I'm all ready for repairs if it breaks again in another 40 years.
Paul Stanleu
07-04-1999 21:51:21
 Re: Oliver 550 fix in reply to Dennis H., 07-03-1999 17:29:47
Thanks for the tip. I put into my "Tractor Info Arcive" on my hard drive
