torque for pressure plate bolts on a 2255
Greg Davis
08-17-2004 06:07:20
Anyone know the torque for the pressure plate bolts on a 2255 with the 3150 Cat engine?
Thanks,
Greg
2255TR
08-17-2004 19:02:59
 Re: torque for pressure plate bolts on a 2255 in reply to Greg Davis, 08-17-2004 06:07:20
The torque spec for the 8 flywheel and pto hub to crankshaft is 60 ft lbs. The spec for the 12 clutch cover retaining bolts is 40 ft lbs. These figures are directly from an original Oliver shop manual. To my knowledge it was not specified but I would recommend to you replacing the 8 (7/16-20 self-locking)cap screws C.A.T. part #5P524 and all 12 (3/8-16)capscrews and internal toothed lockwashers.You will spend a little more money now on parts but WEIGH that against the possible alternative if one bolt would loosen or break.
Greg Davis
08-18-2004 05:10:27
 Re: torque for pressure plate bolts on a 2255 in reply to 2255TR, 08-17-2004 19:02:59
Thanks
