550 Steering
Phil - MO
08-16-2004 05:19:24
The steering locked up in my 550 while I was bush hogging and when I tried to move it the shaft came loose on the steering wheel in the gear box.
Looks like quite a job to repair.
Is their a rebuilt gear box availabe, or am i going to have to rebuild myself?
jakej
08-16-2004 09:05:47
 Re: 550 Steering in reply to Phil - MO, 08-16-2004 05:19:24
A rebuild of your unit is the only way. All parts are available, the usual problem is bearing failure on the shaft due to lack of lubrication. Parts are available from Korves Oliver,Rose Bud Ill. If needed I can send a scan of the steering box, it also shows the position of the gears in the straight ahead position. The dash will have to be removed to remove.
Phil - MO
08-16-2004 11:10:07
 Re: 550 Steering in reply to jakej, 08-16-2004 09:05:47
Thanks.
I called Korves and they have parts in stock.
I have an I&T manual that described how to rebuild. Hopefully this will be good enough.
jakej
08-16-2004 13:58:52
 Re: 550 Steering in reply to Phil - MO, 08-16-2004 11:10:07
What probably happened the upper balls fell out and jammed the ball nut. The shop manual shows the correct positions of each gear and a cut away showing all parts. The IT doesn't show how to align these.
Larry from MD
08-16-2004 05:35:47
Yes but i can't get the name to post
Phil - MO
08-16-2004 07:08:58
 Re: 550 Steering in reply to Larry from MD, 08-16-2004 05:35:47
Try my work email -- [email protected]
or mail to
Phil Sutton
P.O. Box 173
Festus, MO 63028
