Cockshutt 540 throttle troubles
Justin Brown
08-15-2004 17:33:01
Hi,
Recently required a rebuilt Cockshutt 540. I have noticed that it seems to easily start and can sometimes run for hours but other times it is a true buggar. The tractor will run and then start running roughly and will quit unless you quickly pull the choke and release. I have the throttle switch pulled down and it seems to gradually work itself back down reducing the speed but that is another issue. I noticed that the throttle arm that connects from the throttle cable to the carb rocks when it is starting to run roughly (please see link) and this can happen on flat ground as well as hilly territory. I read through some of the forums and I was told that this is a gas issue...so I checked the gas line and sure enough a steady stream of gas is running through the line. The carb bowl was cleaned out as well but that still does not solve it.
I've been told that it could be the govenor or that there could be a hole in the float in the carb. My question is where should I go from here...has anyone else with a Cockshutt had a simular problem? The carb is a Zenith.
Thanks very much in advance...newbie here so don't be too harsh :)
Keith Hewer
08-23-2004 20:16:16
 Re: Cockshutt 540 throttle troubles in reply to Justin Brown, 08-15-2004 17:33:01
firstly, you probably should overhaul the carb, since this is the cheapest to fix. If the throttle shaft holes in the carb are worn oversize, then you need throttle shaft bushings and bore out the carb and install the bushings. You also have a governor problem it sounds like. The governor fora 540 is a flyball governor and when they get worn on the flyball cage, it starts to run erattic. I havecomplete governor available if youso choose. We also have the decals and manuals available for this tractor.Thanks Keith
