Front crank shaft seal
old
08-14-2004 15:52:21
Can a sticker on the crank pulley make the front seal leak oil??
Clint@MD
08-16-2004 07:39:14
 Re: Front crank shaft seal in reply to old, 08-14-2004 15:52:21
Old, I wouldn't think so. Think of all the mud, dirt and grim that builds up on these things and they still keep running strong. That would do far more to make it out of balance than a sticker would. Just my 2 cents.
Time to install the new lip seal from your earlier post I responded to. Easy and cheap.
old
08-16-2004 08:27:07
 Re: Front crank shaft seal in reply to Clint@MD, 08-16-2004 07:39:14
Just to let you know yes it will let it leak, it was a papaer stick on and after I pulled it off it stopped leaking. All I can think of is that since it was paper it was soaking up the oil and then it would let it spin out so to speak.
RAB
08-15-2004 02:33:28
Only if it was heavy enuff 2 throw the crank rihgt out of balance!
