change 550 Oliver gas to dsl.
J Ray
08-14-2004 09:25:20
I have a Oliver 550 gas that has a bad engine, I also have a Oliver s.55 that has a good dsl engine will thay inter change ?
kent
08-18-2004 19:20:11
 Re: change 550 Oliver gas to dsl. in reply to J Ray, 08-14-2004 09:25:20
hi j ray--my email is open--if you will send me your phone # and a good time to call you, i'll give you a call---thanks
kent
kent
08-15-2004 07:41:11
hi j ray--the engine will interchange--i would be interested in what's left over---thanks & let me know
J Ray
08-16-2004 20:27:57
 Re: change 550 Oliver gas to dsl. in reply to kent , 08-15-2004 07:41:11
the S 55 is a complet runing tractor with a davis loader but no PTO ,
so was thinking of changing the moters out.
will sell the s55 as is .
86turbodsl
08-19-2004 19:32:00
 Re: change 550 Oliver gas to dsl. in reply to J Ray, 08-16-2004 20:27:57
I looked into this very carefully, as I was going to do it. some parts are diesel or gas specific, like trans tunnel cover, stuff like that, but you should be able to swap the important bits over fine.
