Oliver 1250 gas with loader
LB
08-13-2004 16:46:25
I just got this tractor yesterday. It runs very good outside of runing a little rich. Loader in good shape and all gear work. However there is no hydraulic pump mounted in front of the engine to operate the 3pt hitch or loader. There is a belt drive pump on the frame rail that operates the powersteering. There is also a hydraulic pump running off the rear pto to operate the loader. It does work but I'd like to put a pump in front so I can make the 3pt useable again and have access to the pto. Anyone have info on what kind of pump to look for. Also any pictures of the pump setup on your tractor would be great. Thanks in advance for any help. PS..I did search on this site and found alot of ill-will towards these tractors. So far mine sounds like the engine runs good.
HAMMER
08-30-2004 19:07:40
 Re: Oliver 1250 gas with loader in reply to LB, 08-13-2004 16:46:25
I"M LOOKING AT A 1250 NOW FOR SELL WITH A CRACKED BLOCKED. CHEAP. SO CAN YOU TELL ME SOME OF THE ILL WILL YOU"VE HEARD? THANKS.
Import Tractor Parts
08-14-2004 18:21:19
We've got new hydraulic pumps for the 1250 Gas; send an email to: [email protected] if you'd like to get one.
