77 Strate cut gears?
Thomas
08-12-2004 20:41:30
our club has a 77 and it has a winny trans it sounds like my HD Chevy pickup when it is in 1st gear under load and it has strate cut gears I was wandering if this is normal they said it has been that way sens they got it and they have had it awile thanks Thomas
Loren
08-13-2004 18:27:39
 Ok, someone compare a 77 noise to a 9N whine. in reply to Thomas, 08-12-2004 20:41:30
My 9N is WAAAY louder than my 77. Opinions from you folk on noise comparisons would help me figure if either is right. Loren
Jim@concordfarms
08-13-2004 12:06:07
 Re: 77 Strate cut gears? in reply to Thomas, 08-12-2004 20:41:30
Kerwin is right, most of the old ones whined pretty loudly. Even my 1959 880 has straight cut gears and it really sings in 6th gear.
Kerwin
08-13-2004 05:58:04
Somebody can correct me if I'm wrong, but I think some transmission noise is normal from these Olivers because of their straight cut gears. I have an 88 RC that puts out a pretty good whine as well when moving along. I think that spherical gearing came in at some point on the 770s, 880s. Hope this helps.
770
08-13-2004 13:44:24
 Re: 77 Strate cut gears? in reply to Kerwin, 08-13-2004 05:58:04
770's had straight cut gears. The later 880's had the helical cut gears. The straight ones will whine from wear, common on the 77's. Keeping the fluid up in them really helps.
Thomas
08-13-2004 19:21:48
 Re: 77 Strate cut gears? in reply to 770, 08-13-2004 13:44:24
I thought it sounded like strat cut gears but the only other oliver simular for me to compar to was grandpas 880 and it dident do it or I dont remember it but I did not realy run it and it went on the auction in 92 thanks thomas
