Oliver 80 engne parts needed
Jeff Wenner
08-12-2004 18:09:52
I"m looking for some engine parts for my oliver 80. I need a valve cover gasket, Oil filter assembly, water pump packing, and the oil seal that is in the timing gear cover around the crank. Anybody know of a good parts source?
Thanks
zac
08-14-2004 08:34:25
 Re: Oliver 80 engne parts needed in reply to Jeff Wenner, 08-12-2004 18:09:52
try olsons gaskets, they have those gaskets and seals, they have a website, just do a search and then email them to say what you need and they will give you a pricelist. hope this helps.
RAB
08-13-2004 00:11:28
Jeff,
Make your gasket. Packing is nothing special - greasy packing is available all sorts of places (plumbers supplies or pump suppliers?). Oil seal is perhaps a case of fitting a modern lip seal, carefully aligning the seal and fixing in position with a self-made housing. No magical engineering expertise needed, just a bit of good luck to get it right first time and may need a further mods to supply a new seal seating!
Is it the whole oil filter assembly or just the filter/cover bowl. If it is just the filter area, another filter arrangement could be made, but I am sure the whole assembly is available from parts dealers, as it is not a particularly highly stressed working part.
Filters from some other engines will fit this engine.
Regards, RAB
