Turbocharging a gas tractor engine VS a diesel one
OX
08-12-2004 15:27:29
Ok, I have the general idea to turbo-up a gas engine, but is the diesel motor the same? can you tell me how to accomplish this.
Russ
08-15-2004 04:08:07
 Re: Turbocharging a gas tractor engine VS a diesel in reply to OX, 08-12-2004 15:27:29
Turbo sounds good; But you will probably need lots of repair funds and more time away from the rest of your life. If you manage to escape all the inevitable weak links after the power increase you will be in a small and unique group of homemade turbo beast owners. Look for a turbo beast from the factory that the current owner has either beat up a bit or lost interest in it for other reasons. The internet may be the best way to find such a beast. Good luck.
770
08-13-2004 13:47:00
None of my business, But years ago a gent around here put a turbo on a 77 gas. The rear end held up fine..... ..HOWEVER, he did bend all 6 connecting rods. Keep in mind it WAS pretty radical..... .
L Klingler
08-13-2004 08:15:49
I don,t know nothin about turbo in gas motor,but my father put a turbo on a 880 oliver diesel.The torbo didn,t last very long the bearings went out,we blamed the low oil pressure 5 till 10 lbs is not enough for turbo. A 310 cu. would be good (1855&1955 put turbo on from factry) & turn the fuel to it. Next problem 77 rear will never hold that kind of power.
cobroller
08-13-2004 21:36:43
 Re: Turbocharging a gas tractor engine VS a diesel in reply to L Klingler, 08-13-2004 08:15:49
We learned by trial & error. You will need to increase the oil pressure. We ended up with a low compression engine running high boost pressure. We kept the mixture on the rich side & injected water & methanol between the carb & turbo to keep the mixture from detonating in the manifold.
