On the Supers..The sheet metal piece the emblem go
super 55
08-11-2004 22:22:31
The small sheet metal piece that is just above the Oliver nameplate on the grill of the supers where the emblem goes,,,,,does anyone make those? And are they different on the Super 55s, 66,77, etc. ? I have a beat up one I found for someone else and I might try fabricating a copy, but I would prefer to find a fabricated one. Just curious.....
JIMSTRAX
08-15-2004 03:50:43
 Re: On the Supers..The sheet metal piece the emble in reply to super 55 , 08-11-2004 22:22:31
I'm missing that piece also on my super55 What did you end up doing Super? making one ?? Jim
super 55
08-15-2004 10:41:26
 Re: On the Supers..The sheet metal piece the emble in reply to JIMSTRAX, 08-15-2004 03:50:43
I am going to try making one. If I am at all successful I'll let you know. I am sure it was made using a press with a tooling die, but I think I can replicate it by hand. There is an embossed area where the emblem goes, I'll have to build that area up with another layer of sheet metal, but the effect should be close. I just have to get my hands on a roller to make the curve. I used to work in a metal shop years ago and wish I had access to all the tools. There is a roller at my school but not in good condition. email me at [email protected] and title your email Nose piece. I'll keep it on record and let you know if I make one. If I get the hang of it I'll make you one, but in the mean time if you find one you better GRAB IT!
jakej
08-12-2004 19:58:12
If you are refering to the sheet metal part to the rear of the nose and covers the radiator cap[ about 11 in long] Korves has them. One of the types I have is hinged at the nose and raised at the rear.
super 55
08-12-2004 21:26:15
 Re: On the Supers..The sheet metal piece the emble in reply to jakej, 08-12-2004 19:58:12
Jake,
No, I bought that from Korves. this is the the pice that goes in front of that cover. I have a link to a picture. It's the piece that the Oliver emblem attaches to. I was mostly wondering if that piece is used on any of the other Olivers of the Super vintage.
jakej
08-13-2004 09:12:07
 Re: On the Supers..The sheet metal piece the emble in reply to super 55 , 08-12-2004 21:26:15
That piece is hard to find, I found one on Ebay with the cover and hinge intact. The one shown can be salvaged a lot easier and cheaper, when welding use .023 wire and protective gas.
super 55
08-13-2004 10:24:36
 Re: On the Supers..The sheet metal piece the emble in reply to jakej, 08-13-2004 09:12:07
Jake, that piece belongs to another fellow. I used it to make a pattern, and I might try fabricating one.
