Oliver 77 W/turbo?
OX
08-11-2004 19:13:05
Can an automotive-type turbocharger be used? or has it got to be from a tractor? and does this work on both gas AND diesel?
Kruse
08-11-2004 19:17:16
 Re: Oliver 77 W/turbo? in reply to OX, 08-11-2004 19:13:05
Ideally, the turbo should be matched to the application. They are not a one-size-fits-all
type of part.
vern in ne ks
08-12-2004 06:09:03
 Re: Oliver 77 W/turbo? in reply to Kruse, 08-11-2004 19:17:16
Over the years I've seen several different set-ups. One that worked quite well, (will go back quite a few years) and was very in-expensive at the time, was to use the turbo set-up from a Corvair Spyder. Probably the key concern is to keep the turbo in line with the size of the engine. Don't think you would want to use one off of a 855 cubic inch Cummins. Have fun.
