Roosamaster
Steve O.
08-11-2004 16:20:16
I"ve just completed a rebuild of my Oliver diesel that I recieved in pieces. What I am not sure about is the fuel shut off handle connection! Does the cable connect to the linkage on the inside "block side" of the Injector pump? I don't have a connection for the cable sheath.Also if this linkage is the correct one do I assume that in the forward position "to the front of the engine the fuel is on,and pulled back to the rear " the fuel is off.
J. Schwiebert
08-11-2004 16:27:23
 Re: Roosamaster in reply to Steve O., 08-11-2004 16:20:16
Answer to first question is yes
The cable cover does not clamp by the pump Alittle clamp held with a 1/4 inc bolt clamps it to the block basically
Yes and make sure it goes al the way forward. I used to make sure by watching the cable flex up a little
