BUD
07-02-1999 15:07:48
Re: Farmall 450 gas or Oliver 1800 diesel in reply to marks, 07-02-1999 14:07:34
I know I shouldn't be saying this on the Oliver board, but I would go with the 450G. For what you are going to use it for, a less powerful, simpler, more reliable tractor is what you need. I have a 450G (I also have a Oliver) and the 450G has never lacked power for plowing snow, pulling a three bottom plow or disk, or pulling logs out of the woods. If you don't know much about tractors like you said, a gas engine is obviously much easier to work on than a diesel. It also will start in the coldest weather where a diesel can give you a few different problems in the cold. My 450 started for me every time I have tried it in the winter, and Wisconsin winters are similar to Minnesota winters. Look at the 450's three point hitch closely if you intend to pull a rear blade. I had a weak homemade one on mine when I bought it and had to replace it. Also, test the brakes, clutch travel, power steering, play in steering, and all gears on both before you decide. If the 450 has a TA, be sure it is working. They are very handy when you need that extra power, but not all of them work that great. I don't know what an 1800D goes for, but $3000 sounds fair for a 450 in good shape with a good three point hitch. I can't tell you what is the better make of tractor between Olivers and Farmalls. I have one of each and I have been lucky with both of them. good luck to you !
