One more time
Herb
08-11-2004 10:55:38
third party image
Greetings!
Question:
1) Is this an orignal drawbar?
2) If I remove the drawbar,can I just attach the lower links,so the unit becomes a 3-pt hitch?
3) If this is possible,what size toplink can I use?
4) If I buy lower lift links,is there a particular length?
Originally,the toplink was a single ended and overload release unit. Unable to find a replacement.
The tractor is a David Brown,disguised as an Oliver 500.
kind regards,
Herb
Canada Grant
08-11-2004 15:44:35
 Re: One more time in reply to Herb, 08-11-2004 10:55:38
#1 : no not original drawbar # 2 Looks like original lift /ajusting links to me ,just add lower drawbars #3 Top link should not matter ,I don't think we had the original one on our 950 Brown #4 Can,t help on lower length but jump over to Case/David Brown board and check with Elmer Landman he will set you straight!
Herb
08-13-2004 06:33:59
 Re: One more time in reply to Canada Grant, 08-11-2004 15:44:35
Thanks for the reply!
