Brake installation on Super 55
super 55
08-09-2004 08:55:49
I am putting all new brake parts in my Super 55 and I have a few questions. When I have the parts assembled without the brake cover the disks actuate fine when I connect them to the pedal and push down. As soon as I put the brake cover on and reconnect to the brake pedal, there is no play what so ever. I measured the thickness of the disks and actuators and they are just slightly small than the depth of the brake cover. Is this normal for new brakes? Any advice would be appreciated.
Myron KY
08-10-2004 05:34:37
 Re: Brake installation on Super 55 in reply to super 55 , 08-09-2004 08:55:49
I had the same problem on my 1850. I found that I needed brake cover shims. These shims go between the brake housing and cover. I don't know if these, shims, were used on the Super 55 or not. You might add some flat washers between the housing and cover as a temporary fix, until you find the correct solution.
HTH
Myron KY
