changing pump in 1550
greg s.
08-09-2004 04:55:50
has anyone changed a hydralic pump in 1550 .Do you have to remove the whole rockshaft assembly or can the pump be removed with top cover removed only??? looking for besy way
j meyer
08-09-2004 08:03:46
 Re: changing pump in 1550 in reply to greg s. , 08-09-2004 04:55:50
I've done it before, but get yourself a service manual and a hoist lined up. Thing sure gets heavy:)
Sam M
08-09-2004 07:35:57
I have changed the hydraulic pump out on a 1555 and a 1650 , both of which are essentially the same tractor from a hydraulic standpoint as the 1550 . The hydraulic pump for this tractor is located in the "top " of the tractor ( essentially underneath the seat ) and can only be reached by unbolting and removing the top . I agree with the other post , either get a service manual or find someone who has done this before because there are some steps that will save you some time . YOu have a bunch of things to unbolt and/or disconnect to get the top off inluding withdrawing the pto drive shaft out the back of the tractor ( there is a spline on this shaft whiich drives the pto pump ) , removing the seat , the gear shift lever , disconnecting the lift arms and remotes and you will need some type of lifting device because the top is heavy . With the top properly unbolted and all items disconnected ( including the lift arms for the three point hitch ) the rockshaft comes off when the top is lifted off . I would wait about ordering a pump until you have the top off and can look at the pump you have . THese tractors came with two different pumps depending on whether the tractor had the hydra electric depth stop remotes and one pump will not work in the other tractor .
Mike (WA)
08-09-2004 08:58:09
 Re: changing pump in 1550 in reply to Sam M , 08-09-2004 07:35:57
I did one some years ago, and don't recall that I had to remove the PTO shaft. The pump drives from underneath, and you can just unbolt it and lift it out (after removing top cover and everything else you mentioned).
Sam M
08-09-2004 11:10:58
 Re: changing pump in 1550 in reply to Mike (WA), 08-09-2004 08:58:09
You are right . I have done it both ways . Once removing the shaft and once not . Seems like now that not removing it was easier . Another reason to get the book and not rely on everyone's opinion .
TheRealRon
08-09-2004 05:13:42
The best way is to buy the service manual. It covers all the steps required.
