Olie/ cockshutt 1900
Big Dan
08-06-2004 16:25:59
does any one have a 4-53 serial and modle number mine has no tag on the rocker cover and detroit wont let me order any parts unless i have thoese numbers all i want it a price out..... .
Lance
08-06-2004 20:13:32
 Re: Olie/ cockshutt 1900 in reply to Big Dan, 08-06-2004 16:25:59
I have an old style oliver 1900 with the two valve per cylinder engine. Is this the style that you have? If so I can get you the serial number.
Big dan
08-06-2004 21:28:52
 Re: Olie/ cockshutt 1900 in reply to Lance, 08-06-2004 20:13:32
yes mines a old 2 valver i have no clue were the old serial number plate went off the valve cover last tiem i did a tune up it was on there that was last feb but i done alot fo field work and who knows were it is. i need the serial and modle number.. Thank yuo very much...
David H
08-10-2004 04:30:39
 Re: Olie/ cockshutt 1900 in reply to Big dan, 08-06-2004 21:28:52
E-mail me and I'll give you mine. Mine doesn't have the tag on the valve cover, but it does have a serial number on the block opposite the blower side stamped in a flat space.
Big dan
08-16-2004 21:42:38
 Re: Olie/ cockshutt 1900 in reply to David H, 08-10-2004 04:30:39
ok i emailed you did you get anything????
