Super 88 hydarlic leak
old
08-06-2004 13:59:29
I'm looseing hydralic fluid but can't seem to find out where since its not going out on the ground. So where might it be going and how hard might it be to fix?? Thanks for any ideas on this
ed
08-06-2004 19:04:00
 Re: Super 88 hydarlic leak in reply to old, 08-06-2004 13:59:29
The hydraulic oil is likely leaking into the transmission. It could be bad seals on the pump or a cracked center plate on the pump. I had the same problem and it turned out to be a cracked plate. To check the pump you have to unbolt the entire hydraulic system housing and remove it from the top of the transmission. Make sure to pull out the pto shaft first as it runs thru the center of the pump.
