Oliver steering???
Franklin Scott
08-03-2004 16:28:48
Have heard that Olivers are hard to steer due to their 6 cylinder engines, even the one that have power steering require a lot of effort...Is this true??? Never driven one, so I don't know....Do all Olivers have 6 cylinders???? What about the Super 55's...
Carm
08-04-2004 07:34:35
 Re: Oliver steering??? in reply to Franklin Scott, 08-03-2004 16:28:48
Our 880 Diesel is a non power setup (It was but no longer). when you are stopped, it takes some effort, but when you are moving, even slowly, it is fine even in tight turns. No problem with non power steering here!
Ed(KS)
08-04-2004 06:45:57
My 1650 steers better than my F250!
Geoffrey in KS
08-04-2004 04:25:32
My Super 77 wide front steers easy even with the power steering not working. If an Oliver without power steering steers hard it"s because the bearings on the steering worm and axle post are shot.
super 55
08-03-2004 23:05:47
 The Super 55s are 4 cylinder in reply to Franklin Scott, 08-03-2004 16:28:48
as are the Super 44, 440, 550, 66, Super 66, 660.
RAB
08-04-2004 06:34:14
 Re: The Super 55s are 4 cylinder in reply to super 55 , 08-03-2004 23:05:47
Not forgetting the 60,80,90,99 and the 18-28, 28-44 and the industrial equivalents which were notated as Hart Parr but marketed after the 1929 merger, the GM engined tractors, OC diesels, HGs..... and any more? V8 cats...
RAB
OliverGuy
08-03-2004 16:56:41
Not true. Oliver has a great power steering setup, driven off the hydraulic pump. The engine has nothing to do with anything. I cart 1 yd. loads of gravel (2,500+ lb.) around in my 1650's loader with one hand on the wheel.
