Cockshutt 60
Sean Asam
08-01-2004 21:26:51
I heave just been given a Cockshutt 60. My son is a total tractor nut and wants it fixed yesterday. I have not yet even located the serial number, I have looked everywhere, I thought that it would be close to the shifter, but I cannot see it. Did all the cockshutt 60 have full side cowlings on both sides? I need a clutch with housing as well as the pulley to go on the PTO next to the shifter.
Ron Grother
09-03-2004 16:03:55
 Re: Cockshutt 60 in reply to Sean Asam, 08-01-2004 21:26:51
have just about every thing you need. Ron
Brian Decatur co. Ia
08-03-2004 09:09:46
From what I know, the Cockshutt 60 is just a repainted Oliver 60. Try Maibach Tractor in Creston Ohio for new and used parts. 1-800-808-9934. They have been the only place that I've found that has sleeves and piston for the 60 engine.
Sean
08-06-2004 19:33:06
 Re: Cockshutt 60 in reply to Brian Decatur co. Ia, 08-03-2004 09:09:46
How much for the sleeves?
08-08-2004 23:19:24
 Re: Cockshutt 60 in reply to Sean, 08-06-2004 19:33:06
$635 for the set of sleeves, pistons, wrist pins, and rings. The pistons and rings aren't actually Oliver items. They have long since been discontinued. If I remember correctly, the sleeves are custom made, and the pistons and rings are supposed to be Continental items. They do give an increased bore. About an 1/8 inch if I remember correctly. Pretty expensive, but if you need 'em, you need 'em.
Keith Hewer
08-03-2004 06:07:18
I have a clutch and pressure plate for csck 60 price 150.00 Canadian. We also make the decals for the Csck 60 for the hoods. Thanks keith
