Fluid or not?
Jim Meade
07-28-2004 19:11:28
I am putting new tires on an 1855. I do very little pulling with this tractor, the heaviest load is a 1,000 gal sprayer but no tillage. Any good reason to put fluid back in?
Thomas
08-10-2004 20:24:20
 Re: Fluid or not? in reply to Jim Meade, 07-28-2004 19:11:28
You Can always put it in later but it is harder to get it all out if you change your mind
GREEN ENVY
07-30-2004 05:53:30
IF YOU DON'T NEED THE EXTRA WEIGHT, DON'T DO IT. IT WILL ONLY ADD TO COMPACTION ISSUES ON YOUR' FIELDS.
jeremy
07-29-2004 06:17:59
I wouldent if you dont till. It also makes it rough if you wont to use the tractor in the cold winter.
Bill
07-28-2004 19:34:11
Not. If you don't need the weight, Y rust out the wheels. And drag all that extra weight around
