770 hydraulic question
John
07-28-2004 14:47:32
OK here goes.... Sitting on the seat, the left side of the unit has only one way hydraulics, the right side is double acting. BELIEVE ME, I tried every concievable hose configuration, looked at owners manual and IT shop mannual..... Could this be "the way it came???" or maybe set up inside this way??? It IS baffling, believe me. I would like both sides to be double acting, but no matter how I set up the left side, I can't get to act double....Any input????? Thanks in advance..
J.
07-28-2004 16:00:53
 Re: 770 hydraulic question in reply to John, 07-28-2004 14:47:32
Both sides were double acting when new. Did you get rid of the momentary restrictor and the line that returns back to the reservoir?
john
07-28-2004 17:15:12
 Re: Re: 770 hydraulic question in reply to J., 07-28-2004 16:00:53
on the left now, I have 3 hoses (single acting). on the left I have two. When I tried both sides double actimg, I hooked it up as in the owners manual, two hoses on each side. 1 restrictor on each side..... No good....How's yours??? I'll will try??? Thanks.
J.Schwiebert
07-28-2004 18:15:43
 Re: Re: Re: 770 hydraulic question in reply to john, 07-28-2004 17:15:12
The left side takes two hoses. The one that is single acting now and the one that goes back in the reservoir. You need to remove the internal momentary restrictor out of this line. There is a plunger on the insideTake it out but don't loose it and if you have the correct ports there will be a pipe plug ahead of the front hose and one between the two hoses. If not Let me know as i am going by memory and I will check in the A M. If not send me a PM on the HPOCA site with a phone number and We can discuss it some more.
John
07-28-2004 19:02:56
 Re: Re: Re: Re: 770 hydraulic question in reply to J.Schwiebert, 07-28-2004 18:15:43
I will try this by the weekend and let you know, Thanks for the help.....By plunger, you mean behind the nipple going in the pump???
J. Schwiebert
07-29-2004 09:24:52
 Re: Re: Re: Re: Re: 770 hydraulic question in reply to John, 07-28-2004 19:02:56
The plunger is in the nipple where the swivel is. I will not see your answer for a week as I am taking the computer to the doctor tomorrow.
John
07-28-2004 17:16:49
correction, on the RIGHT I have 2.....
Jim Meade
07-28-2004 18:49:48
 Re: Re: Re: Re: 770 hydraulic question in reply to John, 07-28-2004 17:16:49
If my memory serves me right, the restrictor is opposite from one side to the other. If the right one is OK, set the hoses on the left up backwards and try that. Going from memory so don't shoot to kill if this isn't the solution.
J. Schwiebert
07-29-2004 04:10:22
 Re: Re: Re: Re: Re: 770 hydraulic question in reply to Jim Meade, 07-28-2004 18:49:48
You are correct. They are opposite from side to side.
