electronic ignition
kevin m.
07-27-2004 19:34:27
I put electronic ignition in my 77 and was woundering if I need A resistor from the coil to the ignition? what would the purpus be? Ithought you wanted A hot coilfor strong spark? doesn't the resistor reduce the power of the coil?
thanks for any help. Kevin
Larry from MD
07-28-2004 05:18:31
 Re: electronic ignition in reply to kevin m., 07-27-2004 19:34:27
It depends if your coil has a built in resistor.You need something or the coil or condenser will overheat and fry.This can happen slow or fast,but the parts wont last.
RAB
07-28-2004 06:49:01
 Re: Re: electronic ignition in reply to Larry from MD, 07-28-2004 05:18:31
He is talkin' electronic. They stopped running 12V DC through the coil on these systems years ago. Seems as though the wiring diagram just needs following.
Regards, RAB
kevin m.
07-28-2004 18:58:16
 Re: Re: Re: electronic ignition in reply to RAB, 07-28-2004 06:49:01
thank you again
