good oliver parts sorce
Adam Suess
07-27-2004 18:30:36
I need a oil slinger for the power buster drive on my 880. I can't seem to sorce one localy. I've never had to go looking beyond local for parts befor and don't have phone #'s for any where else. Any #'s to good oliver salvage parts would be appreciated. Thanks, Adam suess
jeremy
07-29-2004 06:12:47
 Re: good oliver parts sorce in reply to Adam Suess, 07-27-2004 18:30:36
You might try Maibach Tractor in Ohio. Number is(800)808-9934 or (330)939-4192. Web ad is www.maibachtractor.com They should be able to tell you if you need it or not and if they have one. Got some sharp mechanics. They have been good to me and I can get parts new or used in 3 to 4 days and I live in Texas. Fair prices too. Good luck and hope this helps.
Don-Wi
07-28-2004 20:41:17
Wisconsisn Tractor parts
1-877-530-6620
Part of All States Ag Parts
www.asapagparts.com
j meyer
07-27-2004 19:51:26
Fairbo Parts dont have one??? How about Worthington. I do have a couple other contacts in SE Minn here, let me know if you tried those two.
Adam Suess
07-28-2004 06:21:09
 Re: Re: good oliver parts sorce in reply to j meyer, 07-27-2004 19:51:26
I called both those places. Worthington did not have it and apparently the owner of fairbo got hurt and partialy shut down. I've been unable to get ahold of any one there. I also called panning bros in gibbon and one south of worthington but no luck. part is obsolete from agco. Thanks
j meyer
07-28-2004 08:22:11
 Re: Re: Re: good oliver parts sorce in reply to Adam Suess, 07-28-2004 06:21:09
Hmm, okay....How about Judson Implement? I would guess you tried there. Ahhhh, try Dale McNamara from Pine Island, MN. Phone is 507-356-4520. Also, you can try our old Oliver dealership, Dosdall Implement at 651-258-4167. I will say you better call then ASAP, they are on vaction next week, and they close at noon on Fridays. One other person I would try is Dean Smith of Hayfield. He has alot of extra Oliver stuff, and his number is 507-477-3423. Hopefully any of these three can get you going. One more though is that theres a hugh Oliver dealer auction in central Illinois starting tomorrow and going thru Thursday. Maybe if you post really quick, and find someone thats going, get them a part number. Kinda a shot in the dark, but they sometimes work. Hope the summer is going well over in South Central Minnesota, crops look good in Southeastern Minnesota:) Let me know what you find out!!
j meyer
07-28-2004 08:42:25
 Re: Re: Re: Re: good oliver parts sorce in reply to j meyer, 07-28-2004 08:22:11
One more thought would be Larry Harsin in Estherville, IA. If you havent seen his website, its www.olivertractor.com Very nice guy to visit with, and I bet he would have your part!
J.
07-28-2004 15:58:53
 Re: Re: Re: Re: Re: good oliver parts sorce in reply to j meyer, 07-28-2004 08:42:25
Do you have a part numbere and where does this go? In the transmission or in the power booster?
Since you have a lube pump you may not need a slinger depending on what tell me. Send me a P M on the HPOCA web site cause I have a couple more questions.
Adam Suess
07-28-2004 21:20:48
 Re: Re: Re: Re: Re: Re: good oliver parts sorce in reply to J. , 07-28-2004 15:58:53
Thanks for all the comments and suggestions. I have been working with Judson. It's very rare I get turned away from there and I buy most of my parts there as I live 18 miles from them. I called several places today and the part is not to be found. A freind gave me the number to farmersvill, imp some where out east. Didn't have the part either but they have run into this problem befor and have the right book. Tractors SN#93690 and above do not use the slinger mine is a 110xxx SN# change would of been made some time mid 1960. The shop manuals every one else I called had may have been published befor this. They lead you to beleive it is required. This is on the out put gear to the power buster drive(the gear with the sprag in it). Output gear Part# 101 650AS requires the slinger. Output gear Part# 106-161A does not. Oil Slinger is part# 101 657A.
Not sure what a P M is? I'll look. Other wise I un hid my e-mail. Thanks much, Adam
J. Schwiebert
07-29-2004 04:05:21
 Re: Re: Re: Re: Re: Re: Re: good oliver parts sorc in reply to Adam Suess, 07-28-2004 21:20:48
I forgot to tell you in the post above but I am sure you have it figgured it out. Your tractor was made after the slinger was eliminated. So if you have the original gear, you do not need it.
J. Schwiebert
07-29-2004 04:02:28
I started with Oliver when that rebuild program was. I knew since you had a Roosa pump you had a 1961 tractor. We received a new 880 from Charles City with a 112 254 serial number early in 1961 and it did NOT have a Roosa pump. I need to do a little thinking, but I don't think you need that slinger. Did your gear have a part number stamped in it
