OC-3
old
07-20-2004 10:13:23
Well I've got the compression up now and it runs good, but it get hot very hot. Do these engines have a thermostat? Oh by the way the tag on the engine says its a IXF, is this even the correct engine, it does have a water pump but when its running it doesn't look like the water is moveing so I'm thinking either the pump isn't working or theres a tremostat and it isn't opening. Any ideas? Thanks You can also send me e-mails if you want
JD in da UP
07-21-2004 05:05:48
 Re: OC-3 in reply to old, 07-20-2004 10:13:23
I don't know this engine at all, but if it has a water pump, it will have a thermostat, It sounds like you've got a bat thermostat. Bad water pumps will leak and spray water all over. Check the 2 hoses for blockage or collapse as well.
RAB
07-21-2004 00:56:04
Hi, you wrote "Well I've got the compression up now and it runs good"
What is it up to and how did you do that?
I would think by the time the F variant was intoduced, if it had a pump it would have a thermostat as well?
Regards, RAB
old
07-21-2004 07:15:52
 Re: Re: OC-3 in reply to RAB, 07-21-2004 00:56:04
Well the last time I checked the compression it was up to around 90psi, ya thats still not as good as it should be but its a lot better the 55-60psi. I got it up by putting oil in the cylinders and in the exhaust and also spraying PB in the cylinders and letting it sit a few hours. What get me is that it doesn't smoke or use any oil. It does get hot up to 220 yesterday when I shut it back down. I think I may have put the rotor on wrong, its a gear to gear set up so I could only guess how it should be. On the rotor there is a line and on the mag gear there is 2 beveled teeth so I figured that was how to time it but I may have got it one tooth off. By the way RAB thanks
RAB
07-21-2004 10:41:46
 Re: Re: Re: OC-3 in reply to old, 07-21-2004 07:15:52
Hi Old,
Sounds like it was sticking compession rings. Oil control rings are free.
Was it running on non-detergent oil? Probably the reason, as rings gum up much more on this type.
If you have changed over to detergent oil, beware - as it is a bypass oil filter system (on the IXB), I believe, so deposits in the engine could find their way to bearings and narrow oilways before the filtration circuit cleans them out.
Regards, RAB
old
07-21-2004 12:38:59
 Re: Re: Re: Re: OC-3 in reply to RAB, 07-21-2004 10:41:46
Not sure what oil was used in it before I got it and I haven't changed it yet. I want to get all the bugs worked out first then change it. When I change it I'll put in 40 or 50 weight Volvoline raceing oil. The engine on it is a model IXF3 2-3/4X4 bore 2405207 this is off a tag on the engine. It has a Wico mag XH 2600 2-01021. I also have a spare engine its an IXB but is missing the back plate of the engine and also the mag and the head is off of it so if I use it I will put in new rings etc first. Thanks again for the info
Larry from MD
07-21-2004 13:08:57
 Re: Re: Re: Re: Re: OC-3 in reply to old, 07-21-2004 12:38:59
I have one of those mags on my ixb and i think you have the roter correct.The roter should point at one of the wire lugs right after the impulse trips(might be a little past.When cranking slow the impulse trips at the second mark on the flywheel.When running and no impluse the mag fires on the first mark you come to.
