oliver 70 govener oil feed line
sdrewes
07-16-2004 15:10:29
on my oliver 70 on the govener there is that feed line that goes from the top of the govener to the middle of the engine and then there is a Tee fiting and there is a nother line that goes from the engine to i dont know were so were does that line go to cause im missing that line and in my manual it dosent say were it goes does it go to the oil pressure gauge and if it does could i jsut plug it till i get around to getting a new set of gauges for it
RAB
07-16-2004 23:34:01
 Re: oliver 70 govener oil feed line in reply to sdrewes, 07-16-2004 15:10:29
It comes FROM the engine TO the governor.
You must(or at least should) have a means of monitoring the engine oil pressure! Get your guages first or the consequences could be a scrap engine. If you read your manual it gives some very good advice re oil pressure - if you don't have any, shut the engine down immediately and investigate.
Don't know about the 70, but on my other engines of that era, there is a line to the guage and one to the valve gear.
RAB
