Fleetline crank Pulley
Dan
07-15-2004 11:11:10
I am replacing the fan belt on my 66 and I found that it is difficult to slide the inner pulley half to adjust the belt. I was able to tap it back as far as the timing cover.
My question: Is the pulley supposed to be that tight? I am not sure if it is warped or not, but it doesnt seem right. I have the radiator out now, but It would be hard to adjust the belt if it was all back together. Should I pull the pulley hub and check it out? Front seal is leaking anyway so it might be a good idea.
Thanks
