40 and 30 tranny
don
07-12-2004 11:03:07
Are the rear ends of the cockshutts the same?
will one bolt up to the other?
J
07-12-2004 18:55:02
 Re: 40 and 30 tranny in reply to don, 07-12-2004 11:03:07
The 30 rear end is a Detroit or Timken built unit. The 40 is a Cockshutt design.
Phil Heisey-Harleysville,
07-12-2004 17:43:42
Don,
The 30 trans and rear end are MUCH DIFFERENT from the 40/50. The 35, 560-570-570S are similiar to the 40/50. If you do anything with a 40/50 trans. pay very close attention to the numbers that are stamped into the trans housing, just above the side fill plug. NOT all 40/50 trans. have the exact same parts inside. I would not recommend ANY KIND of a DIY match to a 30.
Phil Heisey 215-256-8651 eve. FAX 215-256-1203
Shutt30
07-12-2004 12:16:27
As far as the same, no. Will they bolt up I don't know. The 35,40 and 50 are the same.
