770 Oliver info
Rich Iowa
07-12-2004 05:20:06
I have a few questions about the features of these tractors. Are the hydraulics single acting or double acting, what type of fluid is in the hydraulics, how does the power boost work, how hard is it to find the factory 3 pt hitch? The tractor I'm looking at has a wide front, did Oliver make mounted cultivator for these wide fronts, if so, where would one find these cultivators. I'm sure I'll have more questions in a few days, thanks for any info
Reaver
07-12-2004 17:17:52
 Re: 770 Oliver info in reply to Rich Iowa, 07-12-2004 05:20:06
I recently looked at one of these 770...what is one worth...gas, good condition, with 3pt hitch?
Does the 6 cylinder gas use alot of fuel?
Any other good or bad points?
I'm in Indiana.
Thanks Reaver
Russ
07-13-2004 17:31:57
 Re: Re: 770 Oliver info in reply to Reaver, 07-12-2004 17:17:52
770: 1967 DSL LO 2650, MID 3940, HI 4960. GAS ABOUT 200 LESS. CONDITION AND HAULING DISTANCE WILL ADJUST YOUR OFFER.
Confused
07-14-2004 16:37:49
 Re: Re: Re: 770 Oliver info in reply to Russ, 07-13-2004 17:31:57
Where are you that they bring these prices? a man wanted to sell me a clean 1963 gas for $1600. A 50 horse power straight drawbar tractor or even one with a 3-point around here is a dead item. What do you do with them, drive up and down the road,They are too little to pull wagons. Very few less than 5% make hay. Also the man that said he had a drive in cultivator for a wide front is it a model 750 or 751?
Marty
07-12-2004 09:52:51
I bought a after market three point hitch for my 880 from Saginaw Co. Tractor Paarts 810-638-5787. Website: www.saginawcountytractor.com I thought it a little expensive at 650 and 75 shiping but after seeing how heavy duty and easy to install over drawbar hitch it was a great investment for my tractor.
evilboweviel
07-12-2004 08:21:30
double acting can be adjusted to singles if wanted
a good grade of hydraulic fluid
drops ground speed approx 1/3 when in low
hard, two types avaible
yes, I have a set for sale in central Ohio
good tractors good luck
Ron
