what else for my 70
sdrewes
07-11-2004 15:37:10
trying to get my grandpas old oliver 70 runing again and i rebuilt the carb cleaned out the air cleaner and put new seals in the water pump i need a new alernator cause i broke it but i dont think it worked anyway but besides a new battery and some spark plugs some wiring and some other basic stuff that i know i need what else needs to be cleaned out or rebuilt
Lance
07-11-2004 16:51:01
 Re: what else for my 70 in reply to sdrewes, 07-11-2004 15:37:10
I don't know if you need one or not, but i have a generator for sale instead of an alternator that you are talking about if you want to make it original. It is in pretty good shape but would probably need to be rebuilt at any alternator/generator shop.
sdrewes
07-11-2004 20:46:46
 Re: Re: what else for my 70 in reply to Lance, 07-11-2004 16:51:01
what is the diffrence between a generator and a alternator dont they do the same thing charge the battery wile the tractor is running
RAB
07-11-2004 23:28:49
 Re: Re: Re: what else for my 70 in reply to sdrewes, 07-11-2004 20:46:46
If you look on the net, there will be a whole pile of information for you to find and assimilate.
Basically both are generators. One produces direct current, while the other produces alternating current.
One is fed straight to the battery circuit whereas the alternating current must be rectified before being of use as a battery charging energy source.
The main operational differences are that an AC generator will produce near rating current at the lower end of it's operational range, but the output of a DC generator is somewhat more proportional to machine speed, and as most alternators are a rotating field design, they can be run at much higher rotational speeds, allowing more specific output, than rotating armature machines.
Most AC generators have solid state controllers which basically control the field excitation current, whereas the older DC generators were designed around electro-mechanical regulators.
All this, along with slip rings instead of commutator, no carbon brushes required to transmit the power to the vehicle, smaller overall dimensions and weight, etc. mean that the AC generators are generally more reliable than DC ones. The one thing the AC type will not tolerate is reversed polarity, even for a moment.
Hope this helps, but you will find more on the web.
RAB
Kruse
07-12-2004 03:52:54
 Re: Re: Re: Re: what else for my 70 in reply to RAB, 07-11-2004 23:28:49
You are correct in all that you said. The original
poster wants to know that:
Basically, if you want to go back and make the
tractor 100% original, go with the more expensive
and less reliable generator. If you use the tractor regularly, like your battery fully charged at all times and don't mind that the
tractor has been modified, (for the better)
use an alternator instead of a generator.
RAB
07-12-2004 12:51:04
 Re: Re: Re: Re: Re: what else for my 70 in reply to Kruse, 07-12-2004 03:52:54
We Brits used to call DC generators by their more quaint term - a dynamo. Kinda sets them apart from an alternator, both being electrical generators. Presumably the term came originally from making a motor produce current by turning it (ie force acting on a motor). One simple way of testing a dynamo is to see if it will motor when voltage is applied across it.
Btw 'for the better' is a bit subjective/questionable - as you indicated earlier in your post - the tractor may no longer be 100% original! A bit like changing from 6 to 12 volts, or from magneto to Ketteringham (or even electronic) ignition.
Regards, RAB
sdrewes
07-12-2004 16:06:53
 Re: Re: Re: Re: Re: Re: what else for my 70 in reply to RAB, 07-12-2004 12:51:04
thanks for all that information so does anyone still make generators for oliver 70s cause i need a new one or could i just go to the autoparts store and would they have something that would work its a delco remy thats on it now
Kruse
07-12-2004 17:52:06
 Re: Re: Re: Re: Re: Re: Re: what else for my 70 in reply to sdrewes, 07-12-2004 16:06:53
You could go either way, depending on if you want
it stock or "improved". (By that I mean the
reliability and the increased amperage that is available to charge the battery) A plain-jane
Delco will be the cheapest, but a stock generator
is available at most auto parts stores also. Then
you would also have to buy the voltage regulator
that goes with it and also wire the generator
back to the stock configuration.
My advice: If you use this everyday and want it
reliable, go with the alternator. If you want it
museum stock, put the generator back on.
sdrewes
07-12-2004 20:35:47
 Re: Re: Re: Re: Re: Re: Re: Re: what else for my 7 in reply to Kruse, 07-12-2004 17:52:06
ya i think im going to go with the new and improved alternator cause my tractor is far form a show tractor and if i ever wanted it to be i could always get a old generator to get a new one just take the old one up and they will know what it is
lance
07-12-2004 17:51:53
I have one, but it would probably need to be rebuilt which is not hard to do. Most alternator shops will do it. Let me know if you are intersted.
