How to tell the year of a 70?
john
07-11-2004 13:24:52
My grandpa has an oliver 70 and we want to figure out what year it is. The serial number plate is missing. are there other ways to find out the year? it has 40inch rubber on cast centers,6spd. tranny,distributer,culitivator lift.. im guessing its around a 40 or 41, anyone else have a better idea??
Esev
07-15-2004 16:08:20
 Re: How to tell the year of a 70? in reply to john, 07-11-2004 13:24:52
Check underneath the belly pan, and the transmission housing. Most have casting dates there.
sdrewes
07-11-2004 15:47:06
well i have 2 of my grandpas old 70s one is a 38 and the other is a 44 what you might be able to do is look at the carb(if its the orignal) and see what numbers it has on it cause in the service manual it gives you the diffrent model carbs that were on the diffrent years of the tractors if it has a distributer then its a 38 or later cause i think that was the 38 was the first year they came with one the same goes if it has electric start if you want i will scan the page with the carb numbers and send it to you the 44 has a most of the same stuff some of the stuff that is diffrent you would have to see in person casuse unless you have seen them both there isnt anything to compair to
