WFE
07-07-2004 20:37:50
Re: oliver repower in reply to mfs, 07-07-2004 19:52:11
You'll find that this topic has been debated quite a few times before in the archives of this forum. You can search there for detailed information on proper 310 rebuild procedures and also what is involved in making the 5.9 Cummins fit, but, here's how I see it. The Cummins is a perfectly good motor, to be sure, but is usually at a cost disadvantage compared to rebuilding the 310 (depends what other damage was done when the crank failed and if you can find a cheap used 5.9L Cummins). If preservation of originality is not important, and you want to maximize the power you can get out of this chassis, and you believe you're going to put several thousand hours on the unit, the Cummins is a great choice. If you just want something different, the Cummins is a great candidate for a factory-looking "hot-rod" Ollie. On the other hand, if cost is important, and you can live with the power of the naturally aspirated 310 (87 hp factory but you can add a turbo system from and 1855 to get 98 hp factory or more if you want to juice it a bit), or if you want to preserve originality, rebuilding the 310 is a good choice. As long as 310 rebuilds are done correctly and cover all the bases, the 310 is a remarkably fuel efficient, powerful, and reliable power plant. All of the engine's shortcomings of the past which contributed to its early reputation have today been addressed, and can also be researched in the archives, or just ask and we'll all be happy to help. In your situation, the best course of action depends on the extent of damage done by the broken crank. If the block is intact, you'll want to have all the rods inspected/reconditioned as necessary, and throw out your vibration dampener, a possible/probable cause of the crank failure. A new crank and vibration dampener alone will cost around $1800. Good luck with getting it up and running again. Both are good choices; just depends on your priorities and needs.
