Oliver 1650 Temp Guage Replacement-Need Help
Ed (KS)
07-06-2004 19:48:30
Hello to all Oliver fans!! Well, I made the leap and bought a 1650 diesel a couple of weeks ago...First Tractor! Haven't been so excited about a vehicle since I got my '52 chevy 42 years ago. Been cleaning, shining, changing fluids and learning about it. I ordered a replacement temp guage from RicksAgriParts. The old guage had two terminals, one for a 12 v positive feed from the ignition switch and another with a brown wire that goes to the temp sending unit. The new guage has two upper terminals, one marked T, one marked B. Also two lower screws (terminals?)-- one marked 12 v and the other marked with a ground symbol. There is an unmarked terminal between the two lower screws. Can anyone help me with the proper hook up for the new replacement guage? Thanks and best regards! Ed
Ed (KS)
07-09-2004 11:20:02
 Re: Oliver 1650 Temp Guage Replacement-Need Help in reply to Ed (KS), 07-06-2004 19:48:30
Answer for the record: "B" is hot/battery, "T" is for the sender. The ground
is as marked. Ignore all the other ends. Thanks to Jerry at Ag Parts First.
RAB
07-07-2004 00:13:20
Sounds like the best place to ask your question is direct to Ricks Agri Parts. They should know.
RAB
Ed (KS)
07-07-2004 06:05:02
 Re: Re: Oliver 1650 Temp Guage Replacement-Need He in reply to RAB, 07-07-2004 00:13:20
I be calling them for sure today. I thought someone might have gone through a replacement recently and might be able to answer the question so I could have plugged it in last evening! Thanks! Ed
Bob
07-07-2004 07:08:06
 Re: Re: Re: Oliver 1650 Temp Guage Replacement-Nee in reply to Ed (KS), 07-07-2004 06:05:02
If it is a lighted gauge, the "B" terminal probably powers up the internal "B"ulb, and the "T" probably goes the the "T"emperature Sender.
