Removing blower on oliver 1900
John
07-06-2004 19:10:44
Hi guys:
I'm removing the blower on my tractor ot re seal it and have removed the bolts that mount it to the block and removed the little rubber hose (coupler) that connects the rear blower cover to the rear engine case and it seems like it wants to come out but doesn't have enough room to go foreward. Can i get it out this way or do I have to remove alternator, fuel filter, water pump, etc?
Thanks,
John
John
07-07-2004 18:20:22
 Re: Removing blower on oliver 1900 in reply to John, 07-06-2004 19:10:44
Please help me detroit mechanics, I'm sure someone out there has done this before :)
John
Lee W
07-08-2004 06:33:41
 Re: Re: Removing blower on oliver 1900 in reply to John, 07-07-2004 18:20:22
Did you remove the shaft that drives the blower, it is inside of the rubber hose you took loose. Remove the cover on the back of the engine and take the shaft out if you haven't done that.
