550 Indicator Light
Phil - MO
07-06-2004 04:54:17
I have a later model Oliver 550 (with fiberglass front) and the indicator light on the lower left side of the speed dial cluster is staying on.
Is this a charging indicator light or ?
Battery seems to be staying charged when I was baling.
Allen
07-06-2004 06:31:36
 Re: 550 Indicator Light in reply to Phil - MO, 07-06-2004 04:54:17
I am not the 550 expert by any means but the manual shows the oil light is on the left side and the AMP light on the right side. The tractor also has a buzzer to provide a signal if the oil pressure fails. Hope this helps. Allen
Phil - MO
07-06-2004 06:53:16
 Re: Re: 550 Indicator Light in reply to Allen, 07-06-2004 06:31:36
Thanks.
I better check into this. I hope it's just a short. It started flickering first, and now stays on all the time.
As usual, most of the gauges don't work properly, and some of the wiring was jury rigged before I bought it. I was quite surprised that the light was even wired up.
Mike B
07-13-2004 13:24:37
 Re: Re: Re: 550 Indicator Light in reply to Phil - MO, 07-06-2004 06:53:16
Those indicator lights work by connecting to ground through the sending unit. The bulb will light if the oil pressure is low as it is supposed to, or if the insulation on the bulb holder that snaps into the back of the gauge is worn and shorts to ground. To test it, jump the lead off of the sending unit directly to ground and the light should go on steady (engine off but key on). If you have an ohm meter, the sending unit should go from approximately 1 (closed circuit) to 0 ohms (open circuit) when pressure builds. To be really sure however, you should put in a real oil pressure gauge. I've seen some clean set ups where a gauge is fitted to a tee off of the bottom of the oil filter so that the original idiot light can be used as well.
