Front End Loader for Oliver 1650
Jim Karleskint
07-03-2004 06:37:05
I'm looking for a used front end loader for a 1650 Oliver. Any suggestions on which ones would work and where to find one. I'm in Northeast Kansas.
Ed (KS)
07-06-2004 20:28:19
 Re: Front End Loader for Oliver 1650 in reply to Jim Karleskint, 07-03-2004 06:37:05
Hey Jim, where are you located? I'm in S. LV county. Just got a 1650 diesel. I'll be looking for a loader a bit later myself, so let me know what you find out. I have a list of loaders that I've seen others used if you want it. Ed
Shovelman
07-06-2004 18:48:08
Jim,
I recently mounted a John Deere #48 loader on my 1650G. Had to modify the mounting brackets and convert the control valve from closed center to open center, but in the end it looks and works great. I can put it on or take it off in about 5 minutes.
I took the advice of several on this forum and set the tractor up for power-beyond to run the loader. It was time well spent, as it works well and leaves the remotes available for implements.
I hope this is helpful to you.
Good luck!
Scott
Kevin
07-04-2004 04:43:09
I have a 1650 gas with a Koyker K2 loader on it. Seems to handle it very well
