Power Beyond for Loader
PaMike
06-30-2004 18:57:27
Looked at the 1755 today that I posted about further down on the board. Decent tractor all in all. The guy had the loader hooked up to the rear remotes, and when you lowered the loader it shook up and down. It felt like gavity was working faster than the fluid could return to the tractor. The guy stated that he thought there was a way to use "power beyond" or a port under the seat to plumb in a hydraulic valve so that you could also use the rear remotes. Anybody have any experiance in that?
J. Schwiebert
06-30-2004 19:13:01
 Re: Power Beyond for Loader in reply to PaMike, 06-30-2004 18:57:27
1755 tractors are closed center systems. You do not need power beyond with closed center systems. Yes, you can Tee in another valve. It must be a closed center valve. If the bucket is going down faster than oil is going in, the rate of drop needs to be adjusted. If not in time you will also caviatate the cylinders. If you go with a seperate valve go also with a flow control on the return on both the loader and the bucket cylinders. Make sure it has unrestriced or free flow for the raise positions. Also get a valve that has a float positionfor the loader cylinders
