starts/then stops.
Herb
06-28-2004 10:49:00
Changed all fluids on an Oliver 500 diesel.
Cranked her over and started,engine ran for about 1-2 minutes. Stopped!
Did a fuel system cleaning. By golly!,fired right up!! Then low and beehold,she stopped. Engine ran for about 1-2 minutes.
Did another fuel system cleaning..would not restart.
I'll bee darned!
Any ideas?
Questions:
1)does the fuel tap need to have fuel?
2)does the transfer pump lever stay up or down?
Regards,
Herb
"Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so." Douglas Adams
IanC
06-29-2004 18:58:25
 Re: starts/then stops. in reply to Herb, 06-28-2004 10:49:00
You should also check your return line for a restriction/blockage.
Larry from MD
06-28-2004 17:25:44
The fuel tap does need fuel in it.Make sure fuel will run out of the tank.
J. Schwiebert
06-28-2004 14:14:38
I am not sure what you mean by a fuel system cleaning. Did you put new filters on? Did you just drain the filters. The tractor has a CAV model DPA pump. Perhaps you now have air trapped somewhere. There are also two bleeder screws on the injection pump. You may now need to bleed the filters, the pump and the high pressure side too. You bleed everything but the high side with your primer pump. Questions/
