Oliver fouling #1 #2 plugs
Jim
06-28-2004 09:14:02
My 550 is fouling the #1 plug pretty bad and the #2 somewhat. 3 & 4 are fine. I installed new points, plug wires, carb kit. The tractor does not burn oil or smoke. I was thinking of trying a new coil before moving on. Would a tired coil foul some plugs but not all? Also, is the Pertronix coil advertised on this site a direct bolt-on? Any thoughts or advice would be greatly appreciated! Jim
Scott Green
06-30-2004 03:34:59
 Re: Oliver fouling #1 #2 plugs in reply to Jim, 06-28-2004 09:14:02
Hi Jim. Are you checking out this board on company time??? Well , seeing you have an Oliver , we'll let you slide. See you around.
Yep
06-28-2004 13:37:03
Pertronix will be a direct bolt on for your 550 if you specify to Pertronix what distributor Model and manufacturer you have.
