Ford 300-6 in Oliver 88 ???
Jon
06-26-2004 17:46:49
I have heard of several people putting the 283 Chevy in Olivers. I guess they bolt in pretty easy. I was wondering if anyone has or knows of anyone that has ever put a 300-6 in an Oliver 88.
What do you think? Any info? Any advice?
David
07-03-2004 08:32:27
 Re: Ford 300-6 in Oliver 88 ??? in reply to Jon, 06-26-2004 17:46:49
I'm in the prosess of putting a 300-6 in my 1650. I had to machine a new bellhousing adapter plate, flywheel adapter (I used the oliver flywheel) and I had to front mount the starter to drive off the harmonic balancer. I'll find out soon if it all works.
Kruse
06-27-2004 03:55:48
My only question is who makes the bellhousing
to bolt the Chevy or Ford motor to the Oliver
tranny? Or are you saying the Chevy motor bolts
right up and has the same bolt pattern as the
Oliver? I rather doubt that a Chevy or Ford motor
simply bolts right up to it.....
evielboweviel
06-27-2004 06:14:51
 Re: Re: Ford 300-6 in Oliver 88 ??? in reply to Kruse, 06-27-2004 03:55:48
an 88 has the exposed input shaft to transmission. so you would use bellhousing and pressure plate from engine with clutch disk from tractor. some machine work etc.
Ron
Kruse
06-27-2004 19:54:56
 Re: Re: Re: Ford 300-6 in Oliver 88 ??? in reply to evielboweviel, 06-27-2004 06:14:51
I see.
I guess that would make it somewhat easier.
