880 hookup for a tri wing mower
ed
06-25-2004 16:53:39
hi folks, here is the problem i have a 880 deisel , looking to buy a rhino tri wing the problem is that i can not get the wings to lift. read the manual it said to install a monentary restrictor swivel assembly..that i did at the left rear in place of the regular free-flow assembly,install a quick connect..and then hooked up the line,,,i forgot to mention the mower has single action cylinder..can any one tell me what step i may be missing ,,or the proper way to hook up for a single ation cyl to get the wings up...thank you in advance ..... ed
Roger
06-27-2004 18:16:17
 Re: 880 hookup for a tri wing mower in reply to ed, 06-25-2004 16:53:39
If you are using a newer Rhino mower they require 2200 to 2600 lbs hyd. pressure to make them work. The 880 is probably 1600 to 1800 lbs pressure. Check your out put pressure. I am not sure if you can get larger Hyd. Cyld. for the mower. They would require a lower working pressure.
ed
06-28-2004 17:12:20
 Re: Re: 880 hookup for a tri wing mower in reply to Roger, 06-27-2004 18:16:17
hi rodger, it is a used mower about 1990....as far as the preasure the dealer who has it said it will lift at 850psi. i can get it to go up but it just makes a mess kicking out the hyd fluid, that is were the momentry rest,value come in just hvaent got the hook up down yet...jay as made some suggestions which iam going to try...thanks ed
J. Schwiebert
06-26-2004 19:13:43
You are a little confusing here. Where did you go with the line that attaches to the momentary restrictor/ Also what is the oil capacity of the cylinder(s) on the mower. What model mower?
ed
06-27-2004 09:08:31
 Re: Re: 880 hookup for a tri wing mower in reply to J. Schwiebert, 06-26-2004 19:13:43
hi jay, the line out of the m.r. valve is hooked up with a quick connect to the single line to the mower...it is a rihno tri wing x135..as far as the fliud cap. of the cylinders on the mower i have no idea...any help would be great..thanks ed
J. Schwiebert
06-27-2004 19:39:48
 Re: Re: Re: 880 hookup for a tri wing mower in reply to ed, 06-27-2004 09:08:31
Do you have a specific model for that mower? I will be talking to my local Rino dealer either Tuesday or Wednesday.
J. Schwiebert
06-27-2004 13:17:54
That is what I thought you were trying to tell me. The line with the momentary restrictor goes back in the reservoir. You need to hook your cylinders to the other hose. There is probably a pipe plug on the left side of the reservoir with a good size pipe plug. You will need to bush it down for your hose size. Questions?
ed
06-28-2004 17:04:41
 Re: Re: Re: Re: 880 hookup for a tri wing mower in reply to J. Schwiebert, 06-27-2004 13:17:54
hi jay, got the idea , i was told from the dealer i bought it from to hook it into the small 1/2 inch hole....the unit is rhino x135..tri-wing..thanks for your help ed
ed
06-30-2004 09:05:29
 Re: Re: Re: Re: Re: 880 hookup for a tri wing mowe in reply to ed, 06-28-2004 17:04:41
jay, got it to work using the res.plug which is a 11/4 plug made the connections. and the mowers went up out let psi 1100 psi...thanks for all your help....ed
